If you are not concerned about "correctness", switching to rubber housed 6 volt seal beam tractor headlamps will give noticeably improved illumination over original lights. These lamps run about $25 apiece at Tisco, etc.
However as Jim points out the stock generator can safely power a maximum of only 3 lights - and then only when the engine is running at full RPM.
Unfortunately there is no way to safely boost the output of your stock generator beyond about 15 amps without the risk of burning it out.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
