Re: serial number
Posted by rustyfarmall on September 13, 2011 at 06:40:25 from (216.248.71.224):
In Reply to: serial number posted by John Waterhouse on September 13, 2011 at 06:17:25:
That number is a part number. It is not the serial number, although the serial number SHOULD be on the block somewhere. It will be on a flat, machined area, and will be stamped in.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
