Re: Super A -pieces found in PTO
Posted by Jim Becker on September 20, 2011 at 19:19:18 from (173.57.144.251):
In Reply to: Super A -pieces found in PTO posted by David Lampman on September 20, 2011 at 17:17:15:
Just a guess on the broken pieces, but I'd look at the guides/retainers for the transmission shift forks.
Your PTO difference is a change from the A to the Super A. What you call a "slotted shaft" is from an A. You just need to keep the shifter sleeve mated with a matching upper transmission shaft.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
