Live PTO question
Posted by Skeeter on August 21, 2000 at 10:51:14 from (131.158.72.165):
Hello,
I want to change the fluid in the PTO of my Farmall 400. I found the two plugs on the left side of the PTO case. I assume the fluid should be filled to the level of the top plug (about the middle of the case)? There is also a small hole in the top left rear corner of the case. It had a small piece of cloth jammed in it to plug it up. What is this hole. What is suppose to be in it, as it doesn't look like it is threaded. Use HY-Tran fluid in the PTO, right? Thanks for the help, Skeeter
Post A Followup
: Re: Live PTO question
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
