Re: Stuck Clutch?
Posted by JRSutton on September 22, 2011 at 11:12:56 from (75.130.109.233):
In Reply to: Re: Stuck Clutch? posted by Grumpydaniel on September 22, 2011 at 10:57:32:
If you've got a large open field, you can start it up in gear and hit the brakes a few times (with the clutch pressed in). That should do it.
Not a big fan of doing it this way unless you've got PLENTY of flat ground, and you're real comfortable behind the wheel.
Be sure your brake pedals are locked together, and keep the throttle way down to start.
Latest Ad: 1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen [More Ads]
