Re: 400 rear outside wheel bearing
Posted by pete 23 on September 22, 2011 at 19:59:57 from (74.32.234.149):
In Reply to: 400 rear outside wheel bearing posted by Dean Hoodenpyl on September 22, 2011 at 19:28:54:
You can pull that bearing from the outside, but I never felt it was worth the time of fighting it. I drain, pull pto, take off cap screw, put a forcing screw and spacer between bull gears , turn axle with pipe wrench and push axle out. Then you can push bull gear out of the way and check that inner brg also which is the one that goes to heck most of the time anyway.
Today's Featured Article - The River Tractor - by Charlie English Jr.. This is a 4010 John Deere that was used to farm on the Diamond Island which is in the Ohio River about 15 miles southwest of Evansville, Indiana. About ten years ago, this tractor was parked close to the bank as the river was washing the bank of the island away. ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
