No, the main shaft will pull back from the motor. Once apart, you have a choice based on the way you work and the space available.
You'll need to support the motor and torque tube in place, then roll the rear end back (jack stand supporting the front of the tranny, all resting on a dolly to allow it to roll -- in the absence of honestagawd splitting stands, a furniture dolly under the jack stand will work, there's not a lot of weight on the front of the tranny when split) with the shaft still attached. Rolling the rear back far enough to pull the shaft completely out is not the best way to go.
Better is to roll the rear (somebody on each tire to keep things as straight as possible), back enough, just the 8-10" to get your wrenches onto the bolts on the flex joint. To replace the seal (and bearing, if needed, as Gene pointed out -- what better time, eh?) you only need to remove the bolts that connect the joint to the tranny. That will reduce the risk to potentially damaging two costly bolts instead of all four, and allow you to roll the rear-end further back to better get at the job.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
