656 still not starting and getting frustrated
Posted by don656 on October 04, 2011 at 10:20:42 from (75.179.143.177):
First, I want to thank everyone for all of the help and suggestions.
The latest update is that I do not get any spark from the coil. I put the old coil back on and couldn't get any spark from it either. I took a coil off another engine and couldn't get any spark with it either.
With the ign. switch on, (but not cranking the motor) I have 12 volts from the positive terminal of the coil to ground. I also have 12 volts from the negative terminal (which is connected to the outside distributor terminal) to ground. John T says this should not be, but with the coil disconnected and sitting on a bench, there is only about 1 ohm resistance across these terminals. So, if you have voltage on one terminal, how can you not have it on the other?
I will replace the cable from the distributor cap to the coil tomorrow, but I don't expect that to work either.
I have had the tractor for 10 years. I put about 50 hours a year on it and it has always run well, but now I'm thinking I have spent more time on it than the thing is worth. If the new coil cable doesn't do the trick, I think I will disassemble the tractor and sell it for scrap iron.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
