Posted by kenneth house on October 05, 2011 at 13:45:39 from (173.242.240.24):
In Reply to: H Won't Fire posted by George Rausch on October 04, 2011 at 17:19:20:
if you have a check light or voltmeter, turn on the ignition switch; you should have 6 or 12 volts (whichever system you have) at the coil. if not you have a bad connection, switch etc.
if you have voltage at the coil, you could need a set of points, or ignition coil.
to test the coil remove the short wire going to the distributor, from the distributor. remove the lead wire going from coil to the distributor, replace it with a spark plug wire and insert spark plug and ground the spark plug. then be sure that switch is on and drag the short distributor wire across ground. if coil is good, you should get a spark across spark plug.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
