300 Utility fluid leak and transmission slip
Posted by James Otoupal on August 26, 2000 at 17:43:14 from (209.244.115.110):
I just purchased an International 300 utility LP. It runs great, but has a fluid that leaks from under the middle of the tractor about even with where the pedals would be. It only leaks after the tractor stops running. Recently, the transmission began to slip, and now will not go. What kind of fluid do I use, and where does it go? Is it the pump behind the distributor? it appears to be empty. the PTO will not turn, and the hitch will not move. What kind of fluid goes into this pump. These may sound like goofy questions, but I am a beginner. Thanks for any advice.
Post A Followup
: Re: 300 Utility fluid leak and transmission slip
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
