Re: super h oil leak on steering on front of the tractor
Posted by janicholson on November 11, 2011 at 18:39:31 from (96.24.99.126):
In Reply to: super h oil leak on steering on front of the tractor posted by ajdeereman on November 11, 2011 at 17:43:30:
Either massive disassembly and replacement of bushings and seals, or draining the existing fluid from the front bearing nut, and rincing and drying (no drain on it), then putting Mobil-1 synthetic chassis lube (red) into the box through the top (which was removed to clean out the old oil) this material will stay in the box and be fine for a very og time. If the steering is loose and wobbly, with more than 6" of play before turning the front wheels, I would rebuild it. If pretty tight the grease is a great solution. Jim
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
