Posted by Janicholson on November 30, 2011 at 17:27:18 from (96.24.99.126):
In Reply to: toggle light switch posted by k nelson on November 30, 2011 at 17:07:34:
One wire from the Amp meter to one switch terminal. (choose the Amp guage terminal not connected to the starter switch) All other light wires attach to the other switch terminal. There are two issues to wach out for. There may have been a charg control switch on it. If the original switch has 4 positions, there is one wire going to the wiring harness and from there to the generator F terminal. That wire cannot be used for anything. If you have a voltage regulator on it, and if it is charging, that gen wire will be already disconnected at the generator. The lights are grounded at the lamp assembly, so one wire goes to each from the switch. Jim
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
