Posted by John T on December 11, 2011 at 10:19:31 from (173.243.181.15):
In Reply to: Super C coil issues. posted by Agricon on December 11, 2011 at 09:13:36:
If you were to put a test lamp on the coils input (NOT to distributor) terminal (other test lamp lead to frame ground) and turn on the ignition, THE LIGHT SHOULD LIGHT AS VOLTAGE SHOULD BE PRESENT
HOWEVER if the tractor is just setting there not running with ignition ON and you put the lamp over on the output to distributor terminal ID EXPECT IT TO BE OFF SINCE THE POINTS ARE LIKELY CLOSED THEN.....(if alls wired up correctly and the points are working good and closed)
If you turn her on and crank her over a test lamp on the coils output or distibutor input (from coil) terminal should flash ON (points open) and OFF (points closed)
Heres my Ignition troubleshooting procedure, give it a try
Today's Featured Article - Show Coverage: Godfrey, Illinois Country Days - by Cindy Ladage. Except for last fourth of July's Old Gold show in Springfield, Illinois, I don't remember when it was so hot. Nevertheless, the heat didn't keep vendors and visitors alike from enjoying the third annual Country Day's Event. Jane Elliott said the event was originally a one man show. "Barry Seiler, owner of Country Town Farm Supply store used to invite people up to the Johne Deere store. He would give hats and a free meal for everyone that brings a tractor." Elliott said while this
... [Read Article]
Latest Ad:
[More Ads]
