Re: How to Remove the Bolster
Posted by DeltaRed on December 18, 2011 at 13:33:26 from (71.215.103.43):
In Reply to: How to Remove the Bolster posted by 400D Guy on December 18, 2011 at 12:36:14:
trying not to be mean....From reading your posts,it sounds like you have no idea what you are doing.Mabe you should take it to a professional before you hurt yourself.Loosen the frame rails at the bell housing,the bolster should then fall right out.use a hoist-those things are heavy.Be careful!! and Good luck
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
