timing sweey spot on Regular
Posted by Super-H-Mike on December 20, 2011 at 13:45:36 from (76.164.146.192):
I have been having on and off trouble hand starting my Regular,even with good spark and fuel system sorted out. I am wondering if my timing is a little off. I have the manual, and have checked it that way. I am thinking of hooking up a battery to use an actual timing light on it and expierimenting a little. Is the so called "sweet spot" different from the factory setting? I have heard the old timers say they will start in one crank when all is "just right".... Mine wont, takes about 6-12 cranks, or 15-20 feet if I am pulling it. I know my Mag is working correctly and points are good, carb and compression good. It runs GREAT when running, just tough to hand start sometimes.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
