Re: New water pump leaking
Posted by Nebraska Kirk on January 01, 2012 at 19:02:28 from (207.91.4.159):
In Reply to: New water pump leaking posted by gene bender on January 01, 2012 at 15:07:00:
Why did you remove the bolster just to look at the water pump? Maybe you did not know this, but you can remove the water pump without removing the bolster, radiator or even the fan shroud. I have done it several times on Hs and Ms.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
