Posted by supergrumpy on January 15, 2012 at 05:12:17 from (72.226.44.2):
In Reply to: B414 glow plugs posted by Ed Nelson on January 14, 2012 at 08:01:18:
I have 3414 with those low voltage plugs and it starts great, also have a MF35 23C diesel with similar setup that starts stinking hard
there is a recent post on Tool Talk and another under Ferguson, lots of good info, check the archives
you have to make adapters to fit the modern 12v (10mm 1.25) plugs into the larger holes in your cylinder head, those 12v plugs are very nice
easiest path is to fix the original setup, clean the connections on everything and make sure nothing is burned out, stock glow plugs are reasonable online and resistor (710348R2) is $44 on this site
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
