governor surge on O-6
Posted by Bob in Mi. on January 16, 2012 at 19:57:49 from (67.142.177.26):
Need some info on an O-6 governor, it surges at an idle. Checked tube at carb end and is in place correct. Checked tube above gov. and seems to be correct, not a lot of wear. Pulled cover on gov. and spring is in place but not tight approx. 1/4 to 3/8 of play and spring coils are tight to each other. Spring does not appear to have been bent.
Have adjusted carb and does not change. I do not know any history on this tractor, taken in on trade not running.
Thanks for your help.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
