Posted by Wardner on January 20, 2012 at 02:27:37 from (4.154.235.7):
In Reply to: 460 D posted by metalmender on January 20, 2012 at 01:42:11:
Tell the seller to get it running or you will only give him scrap price which might be around $400 or less if you have to travel alot.
If you drag it home, disconnect the fuel lines at the injectors so that it gets primed while you crank. Give it at least half throttle. Check the glow plugs. Reattach everything and sit on the glow plug button for two minutes. Hit the starter button. It should start if the air intake is xlear. If not, give it a whiff of ether after the glow plugs are cool.
I wouldn't mess around with new fuel. I have started Diesels after 15 years of neglect. .
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
