Posted by Janicholson on January 21, 2012 at 14:47:48 from (67.72.98.45):
In Reply to: electrical trouble posted by Ed Hotaling on January 21, 2012 at 13:05:26:
On a totally different situation and cure potential, the Alt might have a bad diode in the rectifier bridge. This will discharge the battery to the same point is short order (pun intended). A bad regulator in the alt will also do it. A bad diode in the feed to the alt to excite it (if it is not a one wire system) will also do it. Check for battery drain when it is fully charged if you see ,5 volts from a disconnected battery cable to the post, I would suspect the alt. Pull its wire off and check it again. Jim
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1953 Ford Jubilee Tractor. Last driven 5 yrs ago. Parked ever since. As is as seen
[More Ads]
