I built it more or less specifically to pull a 1 row spring tooth cultivator, though did forsee wanting to put a ball on a 3pt drawbar to make it a powered trailer tender.. ie.. back up.. lift trailer tounge off ground and then move it.. etc.
I have plenty of other tractors for heavy work or ground engagement, or load lifting. I started out wanting to make this light duty, and for sure designed it that way when I put the engineering calcs on the paper based ont he geometry. ( putting that engineering degree to some use.. :) ) All calcs were based on mild steel.. which is what I used for the rebar as well, only considering root diameter, not the raised diameter. The scrap rebar I'm using ( liberated from work ) stated it was 'weldable'.. though did not list a grade. I'm makeing a few assumptions based on shear, yeild, tensile and compressive strength. the doubled up hard washers I welded back to back and notched for the rebar are a 'fit' test. i actually have clevis ends for them, were I to finish this project, which I do not currently believe I will. as to the rebar quality levels.. I guess that one is a cr@p shoot. I have no way to grade it, nor do I think a yeild test will be practicle to mock up due to cost vs what I learn from observation. i do have a porta power and could frame up a tensile test, but have a feeling that i'll have a yeilding of a weld joint at a conenction as a first failure before i stretched any bar apart... again.. a guess.. as you point out.. it may have a slag include or void or something that made the bar yeild at a few pounds.. I agree.. that could for sure happen.
As for price.. All items of bulk metal are cut ends and or scrap liberated from work. i had an odd assortment of 1.4 and 2" angle irons to work with 1/4".. along with some 1/4, 1/8 and 1/2" bar stock.. plus iron pipe and a piece of cold roled. ( also liberated some decent expanded metal for use on another project! )
not/bolt assortment cam from bags of stuff I had from other projects.
So far I guess I have a pound of 1/8 welding rod in her, plus the electricity for said pount, plus a few cents of abrasive blade on the chop saw and some incalculable and negligible amount of O/A gas used.
twas all scrap.. so.. I've wasted about 5$ worth of rod and zaputrons used to make them smaller.
bolts I can re-use. etc.
as before, thanks for the insite and comments.
I think I'll probably still be directing my limited funds and energies in a different direction however.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
