Well, Armard, I don't know where you got your Engineering Degree, but you are totally wrong on rebar "being thrown together with different grades of iron". All rebar made in the USA is made to ACI Standards. If above #5 size, it is 60,000psi steel. Which means, it should never be used in conjunction with light-grade angle iron, which is, at best, 30,000psi. Rebar cannot be "properly" welded unless it is heated to the proper degree of heat prior to welding and to the proper degree of heat after welding. A good welder can weld rebar, but without using the ACI methods it sometimes holds and sometimes it comes out like crystal candy - brittle. Don't use rebar for what it's not intended to be used for - for reinforcing concrete.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
