Posted by Michael Soldan on February 15, 2012 at 17:10:26 from (24.235.50.240):
In Reply to: eletric trailer brakes posted by jim warehime on February 14, 2012 at 18:24:51:
as was suggested a bad bearing could cause the drum to contact the shoe,but....a siezed adjuster,an adjuster set too tight, a siezed activation arm, a bad magnet,a bad wire..could be one of many factors..get the drum off,clean everything up and lube all areas that have a moving part or need to move with anti sieze. A bad magnet will be bluish in color from over heating,the face of the drum should be shiny indicating that the magnet has put drag on the actuation arm..most problems I find are rusted siezed parts that will not allow proper application and release of the brake shoes.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
