Posted by Dr. Bert on February 18, 2012 at 14:17:06 from (72.36.56.185):
Several weeks ago I posted about splitting an M and was worried about securing the frame rails to the engine when the bolts were removed. I backed out two bolts on each side, leaving the ends thru the backing plate. In additon, I made two guide bolts and screwed one on each side into the clutch housing and into the frame rails. Separated the halves about one inch, placed a nut between the two halves and screwed a short bolt into the nut and tightened. Rolled the front half away and went to work--replaced seals, checked the throw out bearing and pilot bearing--both OK. Replaced the flywheel ring gear and put in a new clutch plate. The only difficulty I had was that the threads in the bolt holes used to compress the springs in the pressure plate had been destroyed, so I took some 5/16th redi-rod and made three J hooks, inserted then through the slots in the three fingers down to the pressure plate, tightened the nuts and mounted the clutch. Unscrewed the nuts and was done. Bolted the halves together quite easily and this morning mounted the loader and put the old M back to work. Again, thanks to all who took the time to answer my questions and gave advise. Bert
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
