Posted by Janicholson on February 21, 2012 at 18:17:48 from (67.72.98.45):
In Reply to: Re: 656 resistor posted by Jamie656 on February 21, 2012 at 17:19:28:
Electronic ignition is a fine addition to the tractor. It doesn't change the distributor, or replace moving parts except the breaker points. as a result, if it did go belly up, the points can be put back in. I think they provide a better spark, and faster starts (when used with a hotter coil). Far less maintenance. The advance mechanism needs to be checked with a timing light to assure it is operational. The ignition still depends on that mechanical device. Jim
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
