Posted by Andrew Z on February 29, 2012 at 16:46:38 from (64.148.7.32):
In Reply to: Cub Shutdown posted by BruceS. on February 29, 2012 at 16:43:14:
Sounds like you have a dead coil, should restart when cold again. When it occurs again check to see that you have a good hot blue/white spark if it is yellow/orange or none at all you found your problem.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
