Timing is TDC at zero RPM just turning it to set the timing, not running. Put a test light on the terminal going to the distributor (wires connected) with the coil wire grounded and plugs out dist. cap off,(safety) turn the engine with the crank or fan blade. The rotor should point to the #1 plug position just as the light comes on, and just as the timing mark gets to the pointer on the front pulley. This is static timing. Put it together and with a timing light, check to see the running timing (probably close to 22 to 25 degrees. If no advance, or very erratic flashing, the distributor needs to be rebuilt, New springs, and rebushed, then checked for proper advance. Jim
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
