First pull the plug next to the P/S pressure line and install gauge. Turn the steering wheel to the lock and hold it, and note the pressure. Should be 1100-1500 PSI. A) Gauge fluctuates/oil foamy-it's sucking air someplace. Is it full? B) pressure within specs- look externally for the problem, possibly stiff joints in wide front axle,or steering column u-joints. C) Low pressure- you need to isolate the components to determine if you have a low pressure problem due to by-pass in the steering unit or pump. You will have to fabricate some fittings to put a gauge in the pressure line.You need to have a valve between the gauge and steering unit. Engine idling, slowly close the valve and see if the pressure comes up. Do not spin it shut in case the relief valve is stuck closed. You do not specify if it steered before you changed the oil, But I think the steering would be acceptable in the 900-1000PSI range. (with valve closed). If the pump and related components are tight, it will climb to 1500PSI pretty quick. If the pressure continues to climb above 1500PSI as you close the valve, stop the tractor and service the relief valve. Obviously, if the pump is putting out this kind of pressure, the trouble is most likely in the steering unit. Get a 460-560-660 I-T manual, it will tell you how to service it.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
