Re: H idle to wide open throttle and belly pump issue
Posted by rustyfarmall on March 20, 2012 at 08:25:20 from (216.248.71.224):
In Reply to: H idle to wide open throttle and belly pump issue posted by david G on March 20, 2012 at 08:00:04:
I made an adapter that let me use an air impact to remove the coupler shaft. Might be another way, but the impact seemed to be the quickest solution.
Today's Featured Article - Fabricating Sidesheets - by Chris Pratt. The easiest and best first-time project for wanna-be sheet-metal workers like myself is flat or nearly flat metal cut and drilled to be a tractor's sidesheet. A sidesheet is sheetmetal to cover either the engine as in the case of early Oliver's, Massey-Harris' and many crawlers or the wiring and electrical components as in the case of the Massey-Harris Pony, Allis Chalmers' D Series (D-14, D-15, D-12, D-10, D-17, and D-19). The need for fabricating becomes obvious when you go to buy any of these ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
