Re: Re: I Never Thought Of This!!!
Posted by Bill {Antique Acres} on September 16, 2000 at 18:19:47 from (216.192.152.28):
In Reply to: Re: I Never Thought Of This!!! posted by Les Repair on September 16, 2000 at 17:55:17:
I am far from a electrical expert, so please don't hold any of this info against me. But a 6 volt generator will not put out much more than 6 volts unless the brushes are moved. I also am pretty sure that in order to get 12 volts out of a generator the windings inside have to be changed. I am probably way off, but my neighbor has owned a auto electric shop for 25 years and I do know that he has to do something to make a generator 12 volt in addition to adding a 12 volt regulator, beacuse I have watched him do it. Amps plays a big part in charging, but you can have all the amps in the world on a 6 volt system and put on a 12 volt regulator and it won't charge a 12 volt battery. I hope somone else can clear up this muddy water I have made. Thanks Bill {Antique Acres}
Post A Followup
: Re: Re: Re: I Never Thought Of This!!!
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
