W4 Steering Box
Posted by Paul Tombaugh on March 21, 2012 at 14:45:18 from (76.234.42.110):
Restoring a Super W-4 and want to tighten up the steering. There is virtually no play anywhere except for where the horizontal steering arm shaft enters the steering box on the left side. A new bushing there would help remove most of what little play there is at that end of the shaft. The bushing number is 54173D from the TC-50 parts book. Checked with IH dealers and no luck. Before having a new bushing made, thought I'd check to see if anyone knows where one might be found. Also, W-6 and W-4 steering boxes aren't the same are they? (The play isn't in the worm/sector gear and I flipped the gear 180 degrees) Any help would be appreciated!
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
