Re: tisco plug wires
Posted by rustyfarmall on March 22, 2012 at 06:06:20 from (216.248.71.224):
In Reply to: tisco plug wires posted by mkirsch on March 22, 2012 at 05:28:57:
If you put them together that way, it's a wonder it worked at all.
Strip back a portion of the insulation, exposing the wire. Fold that exposed wire back over the top of the insulation, and capture it under the brass terminal when you crimp it in place. Even better is to poke the exposed wire THROUGH that small hole in the terminal, crimp the terminal in place, and then SOLDER the exposed wire to the terminal.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
