Re: Farmall AV left axle rebuild
Posted by Curt Cooke on March 22, 2012 at 13:45:33 from (64.186.50.66):
In Reply to: Farmall AV left axle rebuild posted by ccaissie on March 22, 2012 at 05:29:44:
You will want to replace the seal in the differential carrier, that will be obvious when you take it apart. What you will find is that new seals are less rugged compared to the old ones and you'll find the final drive shaft worn from the original seal. The trick will be to get your new seal to ride on a portion of the diff. shaft that is not grooved.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
