Be sure the disk is situated so that the springs in the hub are away from the flywheel. If they stick out on the Flywheel side the hub will catch the Bolts, and the distance to get it compressed will be way farther than normel. Take the clutch linkage shorter to allow assembly. Use the nuts under the fingers to hold it in compression. (be careful not to drop them into the cover when getting it together, or it will need to come apart again. Use longer bolts to pull the cover closer to the Flywheel, then reinstall the correct bolts. Jim
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
Latest Ad:
1945 Farmall wide body gas with pto and front plow. Runs good but needs new points.
[More Ads]
