Posted by Owen Aaland on March 31, 2012 at 11:35:34 from (216.47.35.132):
In Reply to: What do I have here? posted by Beatles65 on March 30, 2012 at 22:24:21:
That type of hydraulic pump was discussed a while back in regards to vertical mounted distributors. If the pump and distributor drive are good they would indeed be worth as much as the rest of the tractor. They should also fit on an M.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
