merle t said: (quoted from post at 21:59:42 04/13/12) I wired my farmall model a using the wiring diagram.
alternator to amp and amp to starter side thru solnoid also jumper to switch will start fine but does not shut off even when I pull the ground cable.
have been going thru ballast restors also help
My drawing is bad, I know. This is how I did my Farmall 240 I used one Radio Shack switching diode 1N914-1N4148. They come in a 10 pack for a couple bucks. Used an indicator lamp assembly 272--0336 for an idiot light. I added the diode to the light since the light is a 100mA LED it only works for indication and does not have enough power draw, so the diode was needed as well. I left the ammeter in place, but if I have the dash apart again, I would switch to a volt meter. That would be more useful. Hope this information is useful.
-Horsepoor
This post was edited by horsepoor at 14:30:18 04/13/12.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
