What alternator did you use?? If it is a Delco 10si then you need a diode or resister or light bulb in the wire from the #1 terminal on the 2 wire plug. By the way NEVER unhook either one of the battery cables with the engine running because you can/will fry the alternator and can even kill your self if you touch the wrong thing at the right time
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
