Posted by Janicholson on April 24, 2012 at 18:00:23 from (67.72.98.45):
In Reply to: SH Oil pump Gasket posted by VA Gasman on April 24, 2012 at 17:34:45:
The gasket is a shim and gasket as one. THey come in differing thicknesses. CaseIH should still have them. 100% rag content paper will work. Grease the paper before use, and it will be OK. The rotor to cover clearance is tight, .001 max to .0005" Flat sand the cover to assure it is flat with 320 grit Silicon carbide on a piece of flat glass. Thickness can be measured by carefully tightening the pump on a small tab of .001 shim stock. as it is tightened down gently, the gear will seize when moved back and forth a little if it is tighter than .001. If looser, it will not lock up, and the gasket shim is too thick. if it does lock up, a .0005 shim should lock it up. Do not over tighten it with the brass shim stock in it or you will warp the cover. Jim
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
