This is a simplified version from Janicholson, I just did it on my H and it worked PERFECTLY!
1) Take out the spark plugs.
2) Set the intake valve on cylinder No. 1 (front) when its exhaust valve just starts to open. Turn the engine till the exhaust just starts to begin opening (moves) then adjust the intake valve.
3) Set the exhaust when the intake just closes. Rotate more until the intake just closes (just stops moving after having been open) and adjust the exhaust.
Treat every cylinder (pair of valves) the same way, remembering they switch places between cylinders.
The order in a Farmall H is: (front to back EI - IE - EI - IE )
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
