It's very likely that you're just flooded. It'll never start in that condition.
Try this -
Turn the gas off to the carb. Let it sit for a while - like 20 minutes.
Then try starting it as normal - but with the gas off. (be sure to choke it)
When the carb has too much gas in it, it's just not going to work right - But as you crank the engine, it's going to draw gas out of the carb.
If the gas line is shut off (and IS truely shut off - assuming if you've taken the carb off, the shutoff valve IS turning the gas off) then cranking the engine will slowly empty the carb until it hits the magical point where it flows properly and will actually start the engine.
If it does start, it should run long enough to all you to quickly turn the gas back on and you're up and running.
If it fires a few times but doesn't start - you might need to refil the carb and try again - open the gas line for 10 seconds or so to fill it up.
If that process works - it's then your choice - you can either always start the tractor that way - or adjust your floats to keep it from flooding.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
