Re: 39 F-20 governor linkage
Posted by Nebraska Cowman on May 28, 2012 at 18:16:38 from (166.182.3.241):
In Reply to: 39 F-20 governor linkage posted by Central Illinois on May 28, 2012 at 15:43:16:
Am I right to assume you have a variable speed governor and that's just a flat cover that goes on your pic and not linkage? Normally the half moon part of the pivot would be ground off as it is no longer needed. But yes, a 2nd gasket would probably give you clearance.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
