Getting the arm off can be tough but it does need to be removed so the two halves can then be seperated. There are two seals one on the steering shaft and the other on the output shaft. There is also two bushings and a bearing. During the process make sure the grease in the spindles gets to the bottom where the flange rides. I would also replace the bolt holding the steering arm so you have a good surface for your wrench to fit as over the yrs some poor work was done and the head and nut are rounded. I fill with 90wt so the worm and gear get the lube they need. I have done several its quite a job but good steering when done.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
