Re: Oil pan and gas tank leaks
Posted by rustyfarmall on June 20, 2012 at 05:25:55 from (67.55.162.174):
In Reply to: Oil pan and gas tank leaks posted by Zachary Hoyt on June 19, 2012 at 18:58:15:
I had an oil pan from an H that was not only leaking, but was dented right where that leak was. Thought I would try and get the dent out first by hammering from the inside, so I placed a hammer against that dent and then hit that hammer with another hammer. Yes, that dent came out, but at the same time the first hammer went right through the oil pan, creating a BIG hole. I fired up the torch, cut that oil pan into 2 pieces, threw it on the iron pile, and went out and found another oil pan.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
