The clutch Friction plate is installed flat side towards the engine.
All the fingers were the same height
There is approx 1 in of freeplay in the pedal I tried using less but that didnt help
I did replace the pilot bearing(greased) as well as the release bearing. I think the pilot bearing dragging might be the problem I have a gut feeling
I was reading on this forum one person had a similar problem, but was due to a transmission assembly error ( I didn't work on the tranny) and another member mentioned that the splines could be catching the plate
Andrew, Its def not the gears I put the tractor in 1st and turned the engine with the crank with the clutch in (with help) The tractor moves about 2 inches then the clutch slips.
The pilot bearing does not have to be bored after installation right?
I will try messing with the pedal adjustment but I will most likely split the tractor and check on the pilot bearing and the splines on the shaft. When I figure out the problem I will be sure to keep everyone informed. Thanks for the Help, any advice is greatly appreciated!!
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
