Two issues as potential sources of the drag: If thwe friction disk was accidently bent when putting the two halves of the tractor back together, it will drag substantially. If the splines on the clutch shaft are worn, the new disk will bind on them and be forced into the Flywheel. Either will require a resplit. Using a dremel grinder to dress the splines so the wear is not an edge, or removing .065" depth of the splines in the clutch disk hub to allow it to wear where the other disk was happy will also work.
Putting the disk on the shaft when split and turning the shaft will show if there is an issue with a warped hub from installation. Jim
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
