Re: Bottom drain plug on M carb won't budge
Posted by rustyfarmall on July 18, 2012 at 06:31:06 from (67.55.162.174):
In Reply to: Bottom drain plug on M carb won't budge posted by Patrick HMD on July 17, 2012 at 15:02:58:
Hopefully the carb is off the tractor AND disassembled? If so, grab your torch and heat the area around the plug cherry red. Let it cool a bit and then start dousing it with your favorite flavor of penetrating oil. It will smoke a little, but douse it again when the smoke stops and then walk away. Come back in about 30 minutes, grab that plug with your vice-grips and remove it. I've done it that way on every carb I've ever rebuilt and never damaged one. Yes, it is a 1/8" steel pipe plug.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
