I assume the stumble you're referring to is at 1' 04sec, not at 1' 40 sec?
If so, here's my 50cent bet, notice it's a low bet, but worth checking;
Gas cap is not venting properly and you're building up vacumn pressure in the gas tank such that the engine starves for fuel.
Try your test again and exactly when it happens watch the fuel bowl for air bubbling.
Also try immediately shutting the engine off when it happens and quickly move yourself to the gas cap and slowly turn the gas cap and listen for a hissing sound as you turn the gas cap.
Had a similar problem on my SC but only at full throttle. Gas cap was not venting, so bad it caused it to stall. Actually happened more frequently after I put a new gasket under the gas cap, took me a while to connect the dots.
I got another gas cap gasket, trimmed the outside edges smaller so there's was better airflow under the cap, but still sealed the fuel filler neck and drilled out the hole a smidge in the top center of the gas cap that was probably a little quag'd up underneath, problem solved, runs like a champ now.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
