Re: Removing Battery Box with Stuck Bolts
Posted by Mike1972chev on July 21, 2012 at 15:44:51 from (99.186.238.218):
In Reply to: Removing Battery Box with Stuck Bolts posted by F4RM@11 on July 21, 2012 at 14:49:14:
You might try welding a new nut on top of the old,rounded off bolt head.This will do 2 thins:It will give you a NEW surface to use a 6 point socket on,and the heat generated by the welding will help "shock" the threads loose.Let the bolt cool down after welding.(The bolt will expand with the heat,then contract with cooling.)While still slighty warm,shoot more PB blaster around the thred area.Take it EASY with the socket and breaker bar!! ;)
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
