Re: Removing Battery Box with Stuck Bolts
Posted by Brownie 450 on July 22, 2012 at 05:21:39 from (66.43.241.198):
In Reply to: Removing Battery Box with Stuck Bolts posted by F4RM@11 on July 21, 2012 at 14:49:14:
If you can't get the welded on nut to hold for lack of stud length, weld on a thick flat washer, then weld the nut to the flat washer. May have to go a couple of times, but the heat will eventually break the rust.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
