Posted by JRSutton on July 27, 2012 at 20:09:16 from (75.130.109.233):
In Reply to: SA Steering housing posted by equeen on July 27, 2012 at 19:33:02:
You're not doing anything wrong - it's just being difficult.
Here's a few pictures to help confirm what you probably already know should be on the other side. Nothing fancy - that bearing just needs to slide out.
Try to get something under the gear to give you some leverage.
If all alse fails you could use a torch to heat up the casting around the bearing - just don't go too hot - you don't want to crack anything.
Sometimes warming it up a little bit is enough to loosen the grip.
Today's Featured Article - Fabricating Sidesheets - by Chris Pratt. The easiest and best first-time project for wanna-be sheet-metal workers like myself is flat or nearly flat metal cut and drilled to be a tractor's sidesheet. A sidesheet is sheetmetal to cover either the engine as in the case of early Oliver's, Massey-Harris' and many crawlers or the wiring and electrical components as in the case of the Massey-Harris Pony, Allis Chalmers' D Series (D-14, D-15, D-12, D-10, D-17, and D-19). The need for fabricating becomes obvious when you go to buy any of these
... [Read Article]
Latest Ad:
[More Ads]
